Bleeding front brakes
I asked this question on the brakes forum, but am not getting any answers. I am attempting to bleed the brakes on my Bronco and cannot seem to figure out how to losen the bleed valve on the front brakes. Does anyone know what size/type of wrench is required to losen them? Every size I have tried seems like it is going to stip the nut. Thanks!
Typically a 3/8" wrench does the job. If you are having a lot of trouble breaking them loose, they could be seized. Had that happen to me on my last Bronc, ended up replacing the calipers. If you snap one off, you may be able to get the core out with an EZ out. That worked for me, but I was concerned about metal shavings in the cylinder so I replaced the calipers to be safe.
Maybe heat it up with a torch....
You can apply some JB Blaster penetrating spray and a propane torch to it to free it if you haven't mangled it yet. Use either a brake-line wrench or a deep 6-point socket, NOT a 12-point socket (it'll round off the fitting...). Tap the tool with a small mallet or hammer to crack it lose.
Mike
'96 5.8L EB
Mike
'96 5.8L EB
If you've got new hoses, then cut the old ones off close to the steel brake line and when you detach the hose from the steel line, hold the steel line fitting and turn the hose fitting. I've stripped so many of those, then having to cut off the rounded fitting. Its not fun trying to re-flare a line while its on the truck.
Ok that sounds like a Plan that is my next step just got done with the Rotors Thank God I put those Man hubs on last year it makes the Rotors so Much easier!!
Is there a "clip" that holds them in the shock tower????? There seems to be some sort of "clip" there Behind the shock tower. Any advice on that?
Thanks again Everyone here is SO helpfull and FAST!!!
walker1okmedic
12-02-2012 09:28 AM
