This is weird!!
Old 02-04-2005, 07:43 AM
redcrew04's Avatar
redcrew04
redcrew04 is offline
JRFX4........The service manager told me about it,so I looked it up it up on this site.There is a new TSB for nibble/vib that was issued on Jan26. I just had that TSB performed on my truck a couple of days ago. I didnt actually see what the TSB said but my service manager told me that FORD has found the problem and that the tires are to be road forced and then the hubs are to be realligned abd counter balanced. I told the service manager that this TSB has been out for road forcing for awhile . What I was told is that on the new f150s the engineers put a bigger space between the hub and axle to keep the from welding together like on the older f150s. SOooooooo far the nibble is gone I will find out for sure when I take it on a trip next weekend,will keep you posted......
Old 02-08-2005, 03:08 PM
lardman's Avatar
lardman
lardman is offline
Service Bulletin 11781
My service manager did some more digging. The whistling from under the hood is on service bulletin 11781 for hoot-moan-whistle noise. The fix is indeed to add stop-leak pellets to the radiator. Waiting to hear back from him to see how the stop leak pellets would stop the hooting and hollering.
Old 02-09-2005, 05:15 AM
lardman's Avatar
lardman
lardman is offline
Just got more info: There is a sharp angle/protrusion inside the antifreeze cavity causing the whistle. The pellets adhere to the area to smooth out the sharp angle/protrusion. There wasn't much in the description portion on the bulletin.
Old 02-09-2005, 06:23 AM
MotorPsycho's Avatar
MotorPsycho
MotorPsycho is offline
I get the whistle also, but only noticed it after I installed a Volant. That leads me to believe that mine has something to do with the intake. It is sporadic and limited to cold weather.
Enjoy.
Old 02-25-2005, 05:39 AM
lardman's Avatar
lardman
lardman is offline
Correction 17781
Sorry, it is 17781
Old 02-25-2005, 10:25 AM
lardman's Avatar
lardman
lardman is offline
Fyi-this is a special service message, not a tsb
The top line keeps getting cut off. It says "Oasis Special Service Message Number 17781"
fordf150guy
1999 to 2016 Super Duty
03-04-2009 05:22 PM
bismic
12-13-2008 01:17 PM
expy37at
1997-2006 Expedition & Navigator
09-05-2006 09:03 PM
redcrew04
2004 - 2008 F150
01-26-2005 05:29 PM
jasonbbq
11-18-2004 05:47 PM
Quick Reply: This is weird!!
