I like my torque.....do i sacrifice it when I ....
Old 11-06-2002, 10:08 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
Old 11-07-2002, 01:40 PM
Billyboy501's Avatar
Billyboy501
Billyboy501 is offline
I want to put a M5OD in my 1981 f-350 4x4 400 cu 4spd. It has 4.11 gerars and I was wondering how much of a difference swapping my t-18 for a M5OD. I really want the 5th gear. Currently i hardly use my 1st gear cuz its too low. BUt its nice when i want a lot of low end torgue. Should I swap them? and what will be the major losses when i swap to the 5 spd. Will i loose a lot of low end torque? Or is the M5OD like the t-18 but with an "over drive"? It would be very nice to have a 5th gear or an over drive to reduce the RPM's on the highway. Im on the highway 1/2 the time and other half in the the mud What to do???????
Billy
Old 11-07-2002, 02:50 PM
brown 4x4's Avatar
brown 4x4
brown 4x4 is offline
The M5OD is pretty weak doesn't have a great reputation behind even 300 and 302's. Plus the 400 has a big block bellhousing and the M5OD won't fit it anyway. If you really need overdrive, I would swap in a ZF 5 speed instead. You won't lose the low first gear with this tranny either.
1995 F-150 Supercab XLT 155" 4x4 M5OD 302
1986 F-150 4x4 NP435 300
Old 11-09-2002, 05:19 PM
Billyboy501
What is the availability of a ZF5? Do you have one in your truck??
Billy
Old 11-09-2002, 08:56 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
The availability is kinda scarce. If you find an F-250 or 350 with a 460 and 5-speed, this is the tranny it's got. I think they started using them around 91. I helped a friend put one of these trannys into his Bronco, and everything bolted up nice. The low first gear isn't rediculous, like an NP-435, but it isn't too high, like most 5-speeds. The gear spacing is really good too, without a "dead gear".
Jared
russellkr
11-02-2002 11:18 AM
beartracks
10-18-2002 02:20 PM
dale i
09-22-2002 09:37 AM
rogwelch
02-12-2000 11:29 PM
01-28-2000 06:08 PM
Quick Reply: I like my torque.....do i sacrifice it when I ....
