Engine replacement
Engine replacement
Engine swap is going well but slower than I would like. Noticed the front pass tire was toed out badly, when having truck towed? The stabilizer arm had fractured from the front crossmember. That is welded back up and will require realignment.
The main reason to replace engine was triggered by a broke off stud bolt in the water pump. Sourcing a replacement bolt proved to be fairly arduous. I found a US supplier, but cost of $100.00 US for bolt kit and shipping to Canada; 8 day delivery lead me to the wreckers yard yesterday.
3 hours at the yard yielded $2.00 worth of bolts.
Hope to have engine and trans back in by end of weekend.
The following users liked this post:
on
The following 2 users liked this post by EBEAR:
I decided to replace it with a reman. The original engine had high mileage, the whole car cost me $375.00 and lasted me 9 years.
Getting closer
Worked at swapping over pan, thermostat housing, etc on the weekend. Lining up the rod for the distributor turned out to take up some time. The one supplied with the new engine seemed too tall and won't allow the distributor to seat in the block. That meant removing oil pan, oil pump and using old hardware. Going to install plugs, thermostat, oil filter, new cap and rotor. Engine is bolted to trans so close to putting engine back on frame.
Received 4,132 Likes
on
applebaggins
04-07-2018 12:25 PM
51PanelMan
04-03-2005 10:17 PM
