I have a few F4TE 351W questions
on
My plan is to put in a good cam, add a dual plane intake and a 4V carb. I've got long tube headers on it and the stock heads. I plan to use it just to run around in and take it fishing and hunting. I don't need to go fast, I just need to keep good torque so I won't get stuck. I am about 2 weeks away from rebuilding it and I want to get the right cam.
What about the Edelbrock 2281 cam? It has .573 lift with duration of 235/238 @050. At first I will put in the new cam and as I get more money I will add the intake and 650 carb. This cam is in my price range and has the lowest rpm range that I can find without switching to a flat tappet, which I don't want to do. It's $200 plus, of course, the cost of a new timing set and gaskets so it's already adding up to over $300. I want the right cam in place when the other upgrades are ready to be made.
on
No.. that cam won't work at all, WAY to much lift for the stock springs and WAY too much duration for a truck motor. Use one of these...
Lunati 81302LUN - Lunati Street Avenger Hydraulic Roller Tappet Camshafts - Overview - SummitRacing.com
Ford Racing M-6250-E303 - Ford Racing Camshafts - Overview - SummitRacing.com
on
The two cams are almost identical so it probably doesn't matter what one you pick. The matching Lunati springs are a very good idea and get a Cloyes double roller timing set, otherwise the stock lifters and pushrods are fine.
On the edelbrock, the .573/.582 lift with stock rocker ratio is too much? What is the max I can use? The Lunati you suggested before is now a little more than I have to spend. Right now I just want a decent cam in it so I can drive it.
460plowtruck
05-22-2013 12:20 AM
KO1960
07-23-2011 06:16 PM
LBF
28
08-01-2010 04:53 PM
MGT351
04-04-2002 09:26 PM
