Engine ID
Engine ID
So, here goes. I have searched the forums, and I need some help. I have a '65 F250 with the following ID's:
Block - C5AE-A
Heads - C4AE-6090G
Intake - C7TE-9425-F
Exhaust - D2TE-9431-AA
I measured the stroke at 3.78" which I believe is a 390. The block could be either a 352 or 390? It does not have cross bolted mains, so I believe that 427 can be ruled out. I was under the impression that a 390 did not come stock with a "65. Do I have a mismatch of parts, or an engine from another vehicle that made it's way into my truck. Thanks.
Kurt
Block - C5AE-A
Heads - C4AE-6090G
Kurt
Casting numbers don't help much for IDing your engine with the FE. With the measured 3.784" stroke it is a 390 (not much chance of it being a 427 ). You have quite a few different years on those parts so it would be a safe assumption that it isn't original to the truck, aside from being either rebuilt or at least some part swapping done. The engine code in the vin should tell you what came with the truck.
Mike that is not correct. There is the reverse 105 image blocks that many later 360s have, and I believe some of the exotic FEs don't have the 352 on them. That could be challenged.
Most FEs have 352 on the front would be correct but not all.
John
John
Dean8020
06-22-2017 11:47 AM
WentzMetalWorks
19
04-14-2016 07:20 PM
rebocardo
26
01-05-2016 09:25 AM
toddspeed
03-21-2013 11:35 PM
THE-HUNTER
01-18-2013 10:22 AM
