what are the differences between the spring perch meausrements on a 77 f-250 high boy w/dana 44hd and a 79 f-350 w/dana 60? will the 350 axle fit on the 250?
I assume you are talking about the rear axle. My 78 F-350 has a Dana 70 rear axle with a measurement of 45 inches between the center bolt holes on each perch. A Dana 60 is interchangable with the Dana 70 as the 70 is just a beefier rear end. The perch measurments should be identical. The only differences between the F-250 and F-350 rearends are the size (Dana 60, 70, ECT..) UNLESS you go to a dually rearend which will have a narrower measurement due to a narrower frame width. So a F-350 axle SHOULD BE a bolt in on a F-250 as long as the spring perch measurements are the same. Hope this helps!
