78 F 250 REAR spring perch center to center dimension
Looking at the 76 body builders pages there is a difference in whether or not it is a shortbed or if the truck is 2wd or 4wd. Otherwise it does list the dimensions.
Clarify what exacty you have such as f250 4wd 133 wheelbase (single cab longbed). I have the 79 book at home and I can look for you. It should be more accurate for a 78 since 4x4 f250s had some differences after 77.5, assuming you have a 4x4.
For a 2wd 76 f250 133 wb spring perch dimension is 55.56", broken down as 24.29 center of axle to front spring perch center and 31.27 center of axle to rear spring perch center.
http://www.fordification.net/tech/im...6/lwb76_01.jpg
