coolant drain bolts on block?
Old 10-06-2004, 04:16 PM
canucker's Avatar
canucker
canucker is offline
I can only find the drain bolt on the drivers side of the block.Does anyone know where the other one is?
Old 10-06-2004, 04:57 PM
BlueOvalFitter's Avatar
BlueOvalFitter
BlueOvalFitter is offline
The other drain plug is on the passenger side of the block behind the starter.
Old 10-07-2004, 01:09 PM
travlnman's Avatar
travlnman
travlnman is offline
They are the devil to get out!! Mine were very tight.
Old 10-07-2004, 03:47 PM
homer4.2's Avatar
homer4.2
homer4.2 is offline
Usually things are put on real tight so they don't fall off, that's what I'd guess neways..lol j/k Anyways while we are on the topic, how often (mileage wise) does the coolant need to be changed?? 50k miles?
Old 10-07-2004, 05:36 PM
BlueOvalFitter
Every two years or 24k miles.I flush mine once a year.
Old 10-07-2004, 08:02 PM
homer4.2's Avatar
homer4.2
homer4.2 is offline
alright, thanks man. Is this in the owner's manual??
Old 10-07-2004, 09:32 PM
BlueOvalFitter
I'm not sure if it is in the Ford owners manual but it is in the Haynes and Chiltons manuals about flushing 24k miles or every two years.
To me,its cheap insurance to change it once a year,or 12k miles.
Old 10-07-2004, 11:03 PM
homer4.2's Avatar
homer4.2
homer4.2 is offline
Yea, that is a good idea...just like changing every other thing on the truck early...The closer intervals you change it, the longer life you can expect out of your truck, that's just common sense right there, but it's key to do that if you want your truck a long time..
thanks though!
Old 10-14-2004, 09:20 PM
canucker's Avatar
canucker
canucker is offline
do i have to take off both drain plugs? We never could find the second drain plug.My buddy has a prestone backflushing system and hpoefully it will get most of the coolant out.
motown
Modular V8 (4.6L, 5.4L)
09-08-2021 04:01 AM
Deluxe06
04-11-2014 12:13 PM
deyomatic
07-12-2009 11:50 AM
F250racer
04-24-2009 08:41 PM
steuben
11-08-2008 01:20 AM
Quick Reply: coolant drain bolts on block?
