76 F-100 Reverse Lights
Usually on the side of the tranny if it's an automatic. Look on the driver's side of the tranny where the shift lever comes out. You will see a plastic piece with wires coming out of it. Most of the time there are 4 wires. Two of them are the neutral safety circuit that go to the starter relay, and the other two are the back-up lights. You have to take the lever off, and then unbolt the switch from the tranny. The switch is hollow and fits over the shaft coming out of the tranny.
Batman7593
17
05-19-2014 07:30 PM
Stang Thang
28
10-23-2012 08:20 PM
Customcab
15
04-20-2010 02:20 PM
