Do E load range tires wear out faster?
I'm just wondering if E load range tires have to be replaced more often than their standard pressure equivalents. The 235/70 16 XL tires that come on the newer vans are relatively limited in supply, so I'm considering 235/75 16's or 225/75 16's in a D or E load range to open up possibilities as far as finding a deal goes.
All,
First, I run the recommended pressures, 80psi in back and 60psi in front, on my '03 E350. Second, I can tell you that the back tires do, in fact, wear faster than the front ones. I asssssume that this is due to the higher pressue, but that's only an asssssumption on my part. Still, I've gotten/am getting great mileage out of the OEM Goodyear E-load range tires and will probably buy the same when I replace 'em.
DadVan
DadVan
I'd always been told that the rears on a truck or van wore out sooner because they were usually carrying the heaviest part of the load. Which in the case of a work van is true. With my E250 conversion, we'll see. I noticed no appreciable difference between front and rear on my '96 E 150.
Good luck!
Hal
Good luck!
Hal
aurgathor
09-20-2004 08:14 PM
fireball69
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
07-23-2004 11:03 PM
LazyJ_Arabians
07-11-2002 08:13 AM
