99 Ford Ranger Transmission Problem
99 Ford Ranger V6 Transmission Problem
Hello
I have a 99 Ford Ranger XLT V6 Automatic. Today I encountered a weird problem. My ABS light came on for one, and my speedometer doesnt work until I get to 25 MPH. Also, when the Automatic Transmission goes from first gear to second gear, there is a jerk in the process of changing gears. This also goes for when I am going greater than 25 and slow down I also get the jerk when it changes gears. The speedometer doesnt work until I get to 25 and then all gears work fine. Once I go from like 35 down to 25 MPH the speedometer drops to 0. If anyone has any ideas please let me know.
Hello All,
I have a 99 Ford Ranger Automatic Transmission 2WD V6. Today I encountered a weird problem. My ABS light came on for one. Number two, when I am going less than 25 MPH my speedometer doesnt work. Once I get up enough speed my transmission will jerk into second gear and then the speedometer works. This also goes the same for when I am going greater than 25 MPH the speedometer works fine, but once I slow down, the speedometer will drop to 0 once I get to 25 MPH, and the transmission will jerk back into first gear. Automatic transmission arent my favorite, but I gotta have a ride. Someone please help me. Is this a tranny sensor, A throttle cable issue. Someone please give me some insight..
Thanks
JEB
Thanks
JEB
I just talked to a Ford Dealership and they said the ABS Sensor located on the top of the rear end. I dont know maybe that is the speed sensor. But the ABS Sensor came on today and that appears to be when the problem happened. The Ford Dealership said that ABS sensor will cause it to do what it is doing. SO...... I dunno what to do. I just hope it doesnt mess anything up until I get a new one.
The cruise control DOES work. It is weird. Anywhere in the range of 25 MPH or lets say less than 25 MPH the speedometer DOES NOT work. I am goind to the dealership tomorrow. But I was just trying to see if someone has ever heard of this. I mean what would make the ABS light stay on and make my tranny act up?
ABS Sensor??? or VSS???
Vss
Cheap sensor..under $20. Easy to change. Just disconnect electric at the differential. It just screws out, and screw new one in. It feeds computer, speedometer, and cruise. It picks up the ABS tone wring in the diff..sends info to ABS module.
It'a usually at the top of the pumpkin, and don't forget to spray electrical parts cleaner on the plug in.
Not sure I looked under the truck tonight all I saw was a plug that plugs into the top of the rear end. I could not get a close look at it for it was tight situations. I believe I might be able to change it. It just scares me because when I go from first to second gear (automatic) It jerks. But it definately feels like it is coming from the rear end. Visualy I saw electric wires and a plug. My tach is a needle and does not appear to be electric. How do I know if it is electric or cable?
Your speedo is electronic and the signal is generated by the ABS speed sensor (a/k/a VSS or vehicle speed sensor). The VSS also is repsonsible for telling the computer the proper speed at which your tranny should shift. That's why people are recommending that you change that sensor. As mentioned, it is located on the top of the rear differential and secured with one bolt. It is a fairly cheap part, and the average Joe should be able to change it out.
If you continue to experience the same problems after you change that sensor, then the next thing you want to look for is chafed or corroded wiring underneath the drivers seat carpet.
4x4slik
10-10-2016 09:40 AM
Geomin
1983 - 2012 Ranger & B-Series
40
07-24-2015 11:39 PM
