4.2L Head gaskets
4.2L Head gaskets
The head gasket blew on my 1997 F-150 for no apparent reason other than it was poorly designed. The engine never overheated, even with 94,000 miles. The ford mechanic that did the work told me he had two more to do this week for the same reason--blown head gasket resulting in a new long block. To say the least, this is unacceptable!
Hi and welcome to the forum
We dont allow any talk of law suits on here so I had to edit your post.
Even though your truck has never been overheated, it does have 7 or more years and 94,000 miles on it. Things do break and wear out.
Hopefully you caught it before it did any damage and the engine will last a long time still
Replace the engine !. Mine locked up with the same problem. WOund up bending the connecting rod. Cost of a NEW Marshall engine and install was $3600.00. I thought I always knew how to take care of vehicles but gaskets like these are something else to consider. I love my truck but I wish Ford would own up to their 'mistake' instead of trying to slide it past the consumer !
www.leakingfords.com
Well whatsThisButtonDo?'s mechanic said it blew a head gasket. I'm assuming he actually diagnosed it properly and that's what he found. If he had said he had a leak or was losing coolant or something then I would maybe have suggested he look at the intake.
In different parts of the country you'll different problems too. Hot weather places see different problems that places that are cool, different water can cause problems not seen in some places etc.
Where I work I dont honestly think I've ever seen an intake gasket leak coolant on a 4.2. We get problems here that arent seen in other places and other places see problems that we dont see here. A good example is plugged EGR ports. Maybe it's due to different gas here but that just doesn't happen where I live. In other places it happens regularly.
And hey...we can't all be perfect anyway
hotdotdog
05-12-2013 02:26 PM
bruno2
06-08-2012 11:56 AM
