EGR spacer -> manifold gasket
My 1973 400 is equipped with EGR; what is considered acceptable gasket material for the spacer to manifold gasket?
I recently rebuilt my carb and cleaned out the EGR spacer too. I scraped all old gasket material off the EGR spacer and manifold (and carb), and installed a new gasket between the spacer and manifold (and spacer and carb of course). I got a Carquest gasket to go between the spacer and the manifold. It seems to be a paper material. I'm not sure if it's getting a good seal...the parts of the gasket that stick out or aren't covered seem to be stained, as if they're wet. I also had a few light pops out the tailpipe. I feared the gasket was letting air get by...I sprayed all sides of the plate with carb cleaner while idling and the idle never changed, so it doesn't appear to be sucking air. I replaced my points & condensor and reset my timing and the popping hasn't returned. However the stains remain.
I would like to know if that "staining" is normal. If it's not, is it because the gasket isn't acceptable? My mechanic told me that the gaskets he had seen under EGR spacers had steel throughout them and were tougher. But this gasket (cross ref to Fel Pro 60185) seems to be the only style made for this year of 400.
Your thoughts?
Your thoughts?
Superdave
13
12-26-2019 04:04 PM
kramttocs
16
08-21-2016 11:25 PM
rebocardo
26
01-05-2016 09:25 AM
