Explorer is leaning to the left :(
Old 09-07-2002, 01:29 AM
zoti's Avatar
zoti
zoti is offline
Hi,
I have noticed a weird "thing" on my explorer ('98 4WD 4.0L SOHC - 45K). The truck seems to be leaning a bit to the left. If I measure the space between the rear right wheel to the body (from the center to the body - the part above the wheel) and compare it to the left I find that there is a difference of almost one inch. It seems like the truck is "leaning" to the left. It is less noticeable on the front but there is a difference there as well.
The truck doesn't seem to have had any accident (I bought it second hand from the original owner). I looked under the back of it and there isn't any damage visible. All looks in place. The only thing I might have noticed is that the rubber parts that connect the stabilizer arm to the stabilizer bar on the right side seem to be a bit off. But not to a level that will cause such a difference.
I will grab my camera tomorrow and add some pictures of the whole situation.
Any thoughts are appreciated.
Old 09-07-2002, 12:37 PM
zoti's Avatar
zoti
zoti is offline
Pictures can be found on
http://www.pbase.com/zoti/explorer
Thanks for your help.
Zoti
Old 09-07-2002, 01:53 PM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
Was the previous owner overweight?
Old 09-07-2002, 04:58 PM
Dialtone's Avatar
Dialtone
Dialtone is offline
Could your rear shocks possibly be gas charged with one of them giving up the ghost? Try disconnecting both lower shock mounts and re-measure the height. If both side measurements are close, then you definately have a weak shock absorber on one side, if not then a weak spring.
Dialtone
Old 09-07-2002, 10:49 PM
zoti's Avatar
zoti
zoti is offline
No, the guy was not FAT. ;-)
How can I tell if the shocks are gas ?
If it's a spring, What can I do ?
Zoti
Old 09-07-2002, 11:23 PM
Dialtone's Avatar
Dialtone
Dialtone is offline
Gas charged shocks will fully extend on their own if unrestrained. Most shocks nowdays are gas charged to some extent.
I have seen many vehicles with a weak coil spring or two. Only good solution is to replace them (replace them in pairs for a good match). Leaf springs generally not as susceptable to sagging unless constantly overloaded and stressed. If your is a leaf assembly, you may be able to install a spacer between spring and axle tube to raise the low side or drop the high side depending if you have spring over axle or spring under axle, but would be better to get a replacement pair.
Dialtone
Old 09-08-2002, 12:10 AM
nightri1's Avatar
nightri1
nightri1 is offline
jackstraw
07-20-2015 09:43 PM
A/Ox4
1999 to 2016 Super Duty
07-05-2014 06:30 PM
ptwohey
03-20-2014 10:02 AM
Trophy_23
12-18-2011 02:21 AM
Bear_Hunter
04-15-2004 10:25 PM
Quick Reply: Explorer is leaning to the left :(
