Oil leak??
Oil leak??
I was replacing the OEM steering stabilizer when I noticed some area wet with fresh oil. The worst was from just in front of the transmission pan. I put some pics in my gallery.
Any ideas??
https://www.ford-trucks.com/user_gal...&albumid=38127
Any ideas??
Most fluids that end up on the bottom end up black like oil. I'd start by trying to figure out if it's tranny fluid, diesel fuel, or motor oil. You can pull the dust cover off of the flywheel to take a look, but I'd start by grabbing a flashlight and inspecting the valley for any signs of leaks. Any fluids leaking on the top of the motor can work there way down to where your evidence is.
Long late reply.
So I got the O-ring kit from Guzzle and rebuilt the whole fuel filter assembly. And my fuel leak stopped completely. The sleeves in the fuel lines were shredded completely.
Next day, I have a dark oil spot with oil in the valley. So I get the o-ring kit for the HPOP. My buddy changes out the 2 o-rings on the driver's side of the HPOP and it seems to have done the trick.
Thanks to everyone on the site and to Guzzle expecially.
Charlie
Charlie
