towing question
Old 07-10-2001, 07:31 AM
tiwood's Avatar
tiwood
tiwood is offline
towing question
I have a 99 powerstroke with auto transmition and need to know if I should use overdrive to tow a 32 ft. camper. it is about
7000 lb. Please respond asap as we are leaving Wednesday morning.
Old 07-10-2001, 10:45 AM
powerstroker250's Avatar
powerstroker250
powerstroker250 is offline
towing question
If it's not hunting for gears then I wouldn't worry about it. If it is then I would take it out of OD.
Les
Old 07-10-2001, 12:03 PM
logan_85's Avatar
logan_85
logan_85 is offline
towing question
If your out in the middle of nowehere(like me:-)) with no trees/hills/curves/whatever for miles, then use OD. If your around mountains, then I'd suggest not using OD.
Old 07-10-2001, 05:01 PM
mebaim's Avatar
mebaim
mebaim is offline
towing question
[font size="1" color="#FF0000"]LAST EDITED ON 10-Jul-01 AT 06:02 PM (EST)[/font][p]I tow a 29' 5th wheel Wilderness, unloaded weight in the 6500# range. I live in central Pa and when I get out on the Interstate I just let in OD and cruise. I have had no problems with this on the hills. On secondary roads I have seen my tranny hunt and then just simply take it out of OD and run it in 3rd. On the bigger hills, longer and steeper grade, I have found that when my 5th is fully loaded I need to drop it into 3rd to pull these grades.
Hope this helps
Old 07-10-2001, 09:41 PM
tiwood's Avatar
tiwood
tiwood is offline
towing question
Thanks a lot, I will be on flat land in Texas so overdrive will work fine. This is a great forum.
Old 07-18-2001, 02:04 PM
Kinkade's Avatar
Kinkade
Kinkade is offline
towing question
I regularly tow a 12,000# fire truck on a 4,000# trailer all over the midwest. (The fire truck is a classic 1926 Ariens Fox pumper truck.) I only shut off the overdrive when I am climbing a relatively steep hill. Even then, the trans shifts before I get the thought to turn it off manually.
Old 07-19-2001, 07:09 AM
tiwood's Avatar
tiwood
tiwood is offline
towing question
My camper is 8000lb empty and the truck did great. Thanks for the information.
Old 09-30-2001, 05:45 PM
willpower250's Avatar
willpower250
willpower250 is offline
towing question
Just bought my 1st PSD(2001). Regarding the towing question: everyone talks of how great the PSD is. Does anyone have an opinion on the auto tranny that comes with it?Is it up to the task of lasting as long as the motor?
Old 09-30-2001, 10:36 PM
Jeep_Hauler's Avatar
Jeep_Hauler
Jeep_Hauler is offline
towing question
Lockon
2009 - 2014 F150
53
03-29-2020 08:54 PM
jake00
2004 - 2008 F150
04-15-2012 11:04 PM
WIKD
10-19-2010 07:59 PM
FatDutchMn
09-19-2003 12:36 PM
Kenworth
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
01-13-2003 01:50 PM
Quick Reply: towing question
