360 to 410
360 to 410
Can you turn a 360 onto a 410? or are they 2 different motors? If it can what parts would i need to change it over? I have a 360 in a 69 f100 and I want to go play at the local drag strip, there is a 69 chevy truck there that runs a 350 and the guy who runs it is a real smart A--, I think my 360 will take him but i would like to embarass him. anybody got any suggestions.
Originally Posted by 71_4x4_390
a 360/390 with 390 rods and pistons plus a 428 crank will make a 410
i just finished a 410 i built out of my old 360. it was an extream improvement lookin back on that old 2V 360. one word i would like to put in is pitch those old 360 truck rods. i put some C7AE-B rods in mine. held up next to the 360 rods they are much better. also i could find the part number of my pistons i used. your basic 360 pistons will not work. mine came from gessford machine shop, and were special order kieth blacks. not a bad price either. this engine will also need to be externaly balanced. a 428 fly wheel had a balance weight on it. hope this helps, any questions just ask.
The following users liked this post:
I messed up and put a 460 in place of a 390 in my truck. The good news is I hung on to my 390 and all the accessories to get it back in. I am going to do a rebuild before I put it in, and that 410 idea realy looks good. Mudracin74, what is your compression ratio with those Keith black pistons? What grade of gas do you run? and any and all other details that you care to share. The 460 is nice, but it just isn't quite what my 390 was. It also uses a bunch more gas.
the compression of my engine is 10:1, and it dosn't seem to like pump gas much. i ran premium in it once and it didnt run well. after that i put 110 in it. i would bet that if you found pistons that wouldn't be as high compression and a mild cam you could get away easy with pump gas. one thing about the 410 is it has alot of low end torque.
jeremy5wilburn
25
08-15-2016 09:19 AM
17witha664x4
02-29-2012 04:04 PM
tater_51
17
02-21-2010 05:48 PM
