Mass Air
I Asked Ford Racing Tech Guys, They Told Me To Use 93-95 Lightning Mass Air Conversion Since My Bronco Has E4od And The Computer For Lighning Can Also Run Transmission. This Conversion Is Made For Gt40 Lightning Intake, And Is Calibrated For 30 Lb Injectors.
If You Have A 302 Efi / W Aod 88-95 Ford Makes A Mass Air Conversion For That As Well.
Their Are Other Ways To Do The Conversion Do Online Search For Ford Mass Air Conversion.
I,m Still Getting Everything Together To Change My Truck To Mass Air With Lightning Intake And Heads.
Good Luck :-x22
What Year Truck Are You Working On. E4od Trans Makes Conversion A Little More Complicated Than I Expected.
Good Luck :-x22
Originally Posted by Kemicalburns
go here and buy from this guy. www.fordfuelinjection.com. way cheaper and does great work. Guys name is Ryan.
late
late
thanks, have u guys done it before?
Mass air
It uses a heating eliment to measure the amount of air intering the motor. It does this but sensing hot much the eliment cools from the air being pulled by it. The computer then knows how much air is being pulled into the motor, and applies fuel to the amount of air.
I don't know if that help at all-lol
late
late
Go to the site stated above, it will explain mass air and speed density which you have and gives the good/bad of each system. great site with lots of info.
late
