1978 - 1996 Big Bronco
Odd RPM Problem - Please Advise
Old Apr 21, 2004 | 03:04 PM
Crazyromi's Avatar
Crazyromi
I have been having this strange problem with my 96 EB 351 since I drove from Philly to Boston and back a couple of weeks ago. When I am driving at highway speeds and take my foot off the gas the Bronco will coast for a second and then my speed and rpms will have a sharp and noticeable drop. RPMs will drop by about 200, speed by a couple miles per hour. What I was used to was the bronco coasting after I took my foot off the gas with no sharp drop. The best way I can think of describing it is as if I was coasting and then drove through a sizeable puddle. Has anyone ever had something like this happen and what could be the cause? Thanks for the help.
Old Apr 21, 2004 | 04:30 PM
screwy's Avatar
screwy
Quick guess would be tps or iac. Maybe when you let off the gas the engine is starved for a second cause something’s reacting slowly? Weird, I’m going to think about it some more.
Old Apr 21, 2004 | 04:40 PM
Crazyromi's Avatar
Crazyromi
By the way, CEL is not on, so no codes.
Old Apr 21, 2004 | 04:49 PM
Semperfi45601's Avatar
Semperfi45601
I had the same problem in my other car and sometime the engine light would come on and then it would go off again. It was saying it was the MAP sensor but it turned out to just be the vacuum hose had rotted. I am not sure if your bronco has that hose or not but it might be something to check out.
Hope this helps.
Old Apr 21, 2004 | 11:14 PM
greystreak92's Avatar
greystreak92
Semperfi may be on the right track with the MAP sensor since you are dealing with a problem that rears its ugly head when you have a sizable change in manifold pressure. To be certain though, the codes would be the place to start just so you don't end up swapping components needlessly.
Old Apr 22, 2004 | 12:23 AM
quantalimo's Avatar
quantalimo
A map sensor is 50 bucks ....I wouldnt replace it unless your sure...
best two things to do is see if u have voltage at map sensor and see if you have vaccum at the map sensor....
Old May 25, 2004 | 09:35 AM
Crazyromi's Avatar
Crazyromi
Just to follow up on this in case anyone ever comes across this thread in a search. I pulled off my IAC valve and it had a ton of carbon gumming up the spring on the plunger. I took some throttle body cleaner and a paper clip and cleaned the crap out of it. Problem solved, and I didn't have to drop the cash on a new IAC.
