lift kit installation cost?
Hey guys, got my lift kit and now I'm ready to have it installed. I'm gonna do the extended brake lines myself so how much does it cost for a shop to put in the coils, shocks, rear blocks, bracketry, and then alignment? I just want to know what kinda price I should be paying. It's a 2wd f150 btw
thx
thx
I've contemplated doing it myself but business is just too busy right now (plumbing). I can't afford to take even a day off let alone a few right now. And my weekends are consumed by the g/f. If I had access to a lift I'd be more willing to take on the project. I'm having trouble finding shops near me willing to do the work, alot of guys seem real hesitant about it. So as soon as I find one for a reasonable price I'm gonna go with it. thanks
I'm gonna guess that labor is about 8-9 hours at most...@ what...65 an hour? It's expensive man. On my other truck I did it in steps, put the rear brake line on (extended one). Then put the rear blocks on and drove the truck w/ the rear lift in. Then I put the front brake lines on, and then took it off the road for a day to put the front suspension in. You don't need a lift, just some jack stands and a jack or two. Basically you take the tires off, and with a jack under the suspension arm you put just enough to hold it up, no tension on the spring. You remove the shock and then the coil spring comes out in 2 bolts. You remove the end bolt on the radius arm and the pivoting bolt on the suspension arm, remove brake caliper, 2 bolts, and secure it on the upper spring perch, and that whole side of the suspension pops out. Remove the brackets, install new ones, re-assemble and then do the same for the other side. Now this is a very basic explanation, but its an overview. Depends on how much lift and what kind of kit you use (extended radius arms/standard arms w/ drop brackets...or even leaf/blocks in the back).
Is there a good website that has step by step illistrated instructions?
believe it or not.my buddy brought his truck to a shop to have a 6" suspension lift put on his 96 f 250.The guy had to drop his front end and all i know that takes some time but get this now they charged him 3,000 bucks to do it ,and they guy had his truck for a month i dont get it at all.I feel really bad for him i was to busy to do it so he brought it to a shop and got robbed.I meann 3 grand come on should of been more like 300 or 400 hundred.Oh and most shops dont wanna put a lift on cause they dont know how or cause of insurance reasons.
Robert6401
03-07-2012 11:24 AM
4x4, 73, cost, dakota, install, installation, installed, installers, kit, kits, lift, ma, massachusetts, south, spring
