Stock HORN mod!!?!
It consists of the 26" & 29"Hadley's (from a wrecked Freightliner), a 5 gallon tank, a Viair 550C compressor, and solenoids for a semi-truck fan clutch.
The wire you need to access is under the passenger's side battery tray. It is yellow with a green stripe. I also ran 3 lines from that location to a switch under my dash so I can switch back and forth.
As far as capacity, I run my nail guns off of my truck quite a lot now. It is wonderful when your in an area where you cannot easily plug in a compressor.
Hope it helps.
Barrett
Hope it helps.
Barrett
https://www.ford-trucks.com/forums/1...ion-fixed.html
^ Says to try cleaning the plugs for the horns.
https://www.ford-trucks.com/forums/8...horn-wire.html
^ Describes finding the wires for the horn, both by the battery and behind the fuse panel.
Good luck, hope these point you in some kind of direction.
