what size downpipe?
Old 04-22-2004, 07:56 PM
bigtoyfreak's Avatar
bigtoyfreak
bigtoyfreak is offline
what size downpipe?
Hey guys, I have a 2000 F250 PSD and I will be putting a 4" exhaust on it. I need to know what size downpipe to run. I keep hearing that if I go with a 4" downpipe turbo won't spool up till much higher RPM and that using a smaller downpipe creates more exhaust velocity and spins the turbo fast/sooner. If that is the case, is the stock 3" OK or should I jump up to a 3.5"? There will be no muffler on the exhaust and I am currently running an 80hp SuperChip, K&N filter and Wicked Wheel. What are you running and what would you recommend?
Thanks in advance,
Cory
Old 04-22-2004, 08:22 PM
cookie88's Avatar
cookie88
cookie88 is offline
Wierd, lots of downpipe questions tonight. I'll offer you the same advice I just posted in this thread
Old 04-22-2004, 10:53 PM
WeWeld's Avatar
WeWeld
WeWeld is offline
4" downpipe is the only way to go
GENE
Old 04-23-2004, 12:12 AM
bigtoyfreak
thanks for the info guys
Old 04-28-2004, 11:55 AM
gymrat's Avatar
gymrat
gymrat is offline
Look into the Magnaflow exhaust system. The reccomended downpipe size is 3.5" with the balance of the system being 4". The 3.5" downpipe allows for the proper backpressure for the turbo. I have also heard of sealing/connection issues when going from the stock 3" to the 4". Going with the 3.5" allows for a better connection fit.
stevorino
57
06-16-2016 08:59 AM
bduemig
09-22-2014 04:23 PM
bduemig
07-11-2014 12:58 AM
dave91gt
11-16-2010 11:55 AM
1957F100
03-28-2009 10:28 PM
Quick Reply: what size downpipe?
