Keypad & Mirror's Not Working - GEM Module Maybe?
Fuse for mirrors is position 4 (5 amp) in the power dist. box under hood. This same fuse as well as position 8 (5 amp) control the RAP module (antitheft module). Check these again.
If fuses good, Check the switch for the mirrors. The mirrors are seperate from the GEM. If the mirrors dont work, I suggest replacing the switch on the door.
Accessory Man
11-13-2016 06:26 PM
