Oil & Lubrication
Can you mix Mercon and Mercon V?
Old 03-05-2004, 11:24 AM
fireball69's Avatar
fireball69
fireball69 is offline
Can you mix MERCON and MERCON V together? I had my trans flushed last week and want to change the trans filter now. The dipstick on the trans says use MERCON and when I took it in to Firestone to get it flushed the guy told me I needed MERCON V (a synthetic). The receipt does not say what fluid was put in.
Can they be mixed? If not, how can I tell what was put in without flushing the whole system again?
Thanks
Old 03-05-2004, 01:09 PM
jimandmandy's Avatar
jimandmandy
jimandmandy is offline
Mercon V is not, by specification, synthetic. It is usually a hydroprocessed blend that is Dexron/Mercon/Mercon V. Unless you have an E4OD that specifically prohibits Mercon V, you are fine. Since you have a 4.6 4x2 F-150, you dont have the E4OD. There should be no worry about mixing Mercon fluids in your case.
GM has an ATF spec that is backward compatible to 1949. Why does Ford, and worse, DaimlerChrysler with "dealer only" +4, have to make it so complicated?
Jim
Old 03-05-2004, 02:20 PM
fireball69's Avatar
fireball69
Thanks, it's good to know that I'm OK either way. The trans is a 4R70W. I'll change the filter tomorrow after work. Thanks again.
Old 03-07-2004, 08:17 PM
Rockledge's Avatar
Rockledge
Rockledge is offline
Originally Ford recommend using "Mercon" in the 4R70W out of the factory right up until 1997. That is why it's written on your dipstick. Beginning in 1998, "Mercon V" became the standard for that tranny.
However, I'm pretty sure that the Ford tranny guys changed their tune a few years ago and determined that "Mercon V" should now be used in the 4R70W tranny for ALL years. So maybe Firestone was actually on top of things by telling you that.
Old 03-08-2004, 09:57 AM
Rockledge's Avatar
Rockledge
Here is the source of my information about all 4R70W trannies now requiring Mercon V:
Tranny Fluid for the AODE-4R70W
Old 03-08-2004, 06:41 PM
fireball69's Avatar
fireball69
Thanks Rockledge fir the information and followup. Used the Mercon V when changing the filter.
Old 03-10-2004, 08:52 PM
fellro86's Avatar
fellro86
fellro86 is offline
General rule of thumb is that the upgrades are typically safe, just the newer version. Usually you can upgrade an older trans to the newer stuff, just don't try to put older oil into an newer trans, (like if you had a stockpile of it) Only exception is the older Type F tranny's, but then that's why it says type f, not Mercon.
Old 03-10-2004, 09:12 PM
rusty70f100's Avatar
rusty70f100
rusty70f100 is offline
Just dont try to put Mercon in a trans requiring Type F. Your intermediate band will go bye-bye in a big hurry. Trust me, I learned the hard way.
Old 03-10-2004, 09:33 PM
Rockledge's Avatar
Rockledge
You don't really want to use Mercon V in an older AXODE/AX4S tranny, either.
On the other hand, you should be adament about using it in one built after '97.
01FordEx
03-28-2016 10:59 AM
AmmoDawg
1997-2006 Expedition & Navigator
01-08-2013 09:26 AM
tonyford
Escape & Escape Hybrid
11-30-2010 11:21 AM
whatstar1117
Aerostar
11-18-2009 04:47 PM
Redranger03
1983 - 2012 Ranger & B-Series
10-01-2009 03:48 PM
Quick Reply: Can you mix Mercon and Mercon V?
