Pre-turbo pyrometer probe install.
When installing a clamp on EGT probe pre-turbo, should I be concerned with metal filings falling into the pipe and going through the turbo? Should the pipe be taken out to be drilled?
Also, how far from the turbo should the probe be installed? Which side is drilled easier and from above or below?
Thanks!
Matt
I am hoping to use this kit with single pillar pod.
http://members.rogers.com/mattjibb/4344_large.jpg
Thanks!
Matt
[updated:LAST EDITED ON 26-Mar-02 AT 04:43 PM (EST)]>When installing a clamp on EGT probe pre-turbo, should I be
>drilled?
>Thanks!
>Matt
No need to worry about shavings, 99% of them fall in your face so wear safety glasses. Don't take the pipe off, just drill it, then start the truck and IDLE the engine for a minute. Any shavings that MAY have entered the pipe will blow right past the turbine blades. Drill the hole about 1-1 1/2" after the exhaust manifold on the bottom of the pipe on the driver's side. It's the easiest. Look at my pics for my installation.
Les
>drilled?
>Thanks!
>Matt
Les
>Good luck Weldman
>Les
he's gonna need it he owns a diesel !
I can't resist doing this tonight,it's too much fun!
Nice kit
Must be for some kind of diesel turbo protection!
Only the diesel gods would know ,It ain't used on gassers
thats for sure!!!!
Rich
Ford Trucks Built Tough!
not with rocks
Watch out "X" Mayor of Truckville
>Les
Nice kit
thats for sure!!!!
Rich
not with rocks
clydesride
15
02-14-2012 02:18 PM
franksuek
1999 to 2016 Super Duty
12-29-2011 05:55 PM
JoeBoost
11-06-2002 06:13 AM
red99sdv10
03-26-2002 03:44 PM
