Where to mount E.G.T probe ???????
Old Nov 4, 2002 | 08:44 AM
JoeBoost's Avatar
JoeBoost
I recently got my Autometer E.G.T gauge , and i have not a clue where to mount the Probe. The instructions say to mount it Pre-Turbo for a more accurate reading , but where "PRE-TURBO" is the question. If someone could possibily take a pic , or give detailed instructions to where i should put this thing i would appreciate it ...
Thanks ,
Old Nov 4, 2002 | 09:55 AM
Distinctive Dave's Avatar
Distinctive Dave
>Thanks ,
Joe
I got a pic taken, its not the best but it should help. I will put it in my user gallery for you to look at. This probe is placed on the drivers side of the truck. ITs the lowest point of the exhaust manifold. If you crawl under the truck right by the drivers door and look up you should see the same thing under your truck as you see in the pic.
2001 F-350 CC Lariat 4X4 LB PSD SRW, Heated leather, off road package, western snow plow, strobe lights in parking lights, headlights and backup lights, tinted windows, stull billet insert, pioneer cd player, rockford fosgate 700S amp rocking 3 JL Audio 10W0's behind back seat,Infinity Interiors and an Alpine amp, husky liners front and back,Banks transcommand, K&N FIPK, Diablo Sport 110HP chip, Hypermax pryo/boost gauge, Hypermax 3.5 inch downpipe and 5 inch exhaust.
2002 F-350 XL 4X4 PSD DRW, XL Decor Package, 9' Heil Dump Body, 8' Western (for now) Poly Plow, Strobes Front and Back, toolboxes and Wheel Simulators.
Old Nov 4, 2002 | 02:27 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Are you using a clamp on thermocouple? If you are it's like Dave said, only you're not drilling through the exhaust manifold, you're drilling through the up-pipe to the turbo right after the manifold. Just pick a flat spot in the pipe that is easily accessible (you'll see it right away once you get under there) and follow the Autometer instructions.
Old Nov 5, 2002 | 07:04 AM
powerstroker250's Avatar
powerstroker250
I have the clamp on version mounted pre-turbo. You can see it in my pics.
Les
Old Nov 6, 2002 | 05:32 AM
bilder12's Avatar
bilder12
Pre-Turbo will be the exhaust thingie that comes right off the manifold on the driver's side of the truck. About 6 inches from where the pipe connects at the manifold. Pick a spot that will not interfere with the probe wires and have at it. While running the wire from the "stinger" up to the inside of the car so they wont get burned and ground out. Also make sure you dont pull the connectors off the wire ends. Should that happen - DO NOT SOLDER. Get new ends and clamp them on. Have fun on your run.:+
Old Nov 6, 2002 | 06:13 AM
FortyFords's Avatar
FortyFords
Shake-N-Bake
23
Apr 7, 2010 08:16 PM
jeffreystar
Mar 15, 2006 10:05 AM
smokin redneck
33
Nov 22, 2004 08:17 AM
HzrInAz
19
Jun 20, 2003 07:57 PM
weldman
Mar 28, 2002 11:13 AM
