When installing a clamp on EGT probe pre-turbo, should I be concerned with metal filings falling into the pipe and going through the turbo? Should the pipe be taken out to be drilled?
Also, how far from the turbo should the probe be installed? Which side is drilled easier and from above or below?
Thanks!
Matt
I am hoping to use this kit with single pillar pod.
http://members.rogers.com/mattjibb/4344_large.jpg
