Now, this takes the cake
I posted here about a month ago about my air bag warning light on the dash staying on all the time. I got it tested, and it was traced to a failed GEM module.
OK, that should be covered by Ford Restraint System warranty of 5 years, right?
Wrong. The service manager insisted that my basic warranty expired after 3 years, thus I would have to pay for the repair.
I told him the Restraint System warranty is 5 years.
NO!
Then he said the problem was probably caused by a water leak on the driver side cowl panel, causing a short.
In the first place, there is NO proof I have a water leak.
The FACT is, I have a failed GEM module, which should be covered by Ford warranty.
I contacted Ford Motor Co. and they are investigating the matter.
Right now I'm so ticked off, I'm seriously considering buying a Chevy truck.
BossHawg
NO!
BossHawg
Racerguy,
No, they did not write down the code they received. But I just received a phone call from Ford Motor Co. They will contact the dealer and they are going to fix it under warranty.
I guess that proves, you should always go to the top (or in this case, Dearborn).
Thanks to all of you for your help, and allowing me to vent.
I can't believe I even entertained the thought of buying a Chevy.
It must have been temporary insanity.
Thanks to all of you!
BossHawg
BossHawg
With a little theropy and some hipnosis, I believe that we can rid you of your Chevy demons!
I got close to that once, so I took a 2x4 and whapped myself in the head with it a few times, straightened me right up. Instead of seeing stars, I saw blue Ford ovals floating around every where. Then, when I came to, all had been forgotten about that whatchcallit brank truck.
