Will A Ford '97 Radio/CD Fit Into My '94 F150?
Old 01-01-2004, 12:40 AM
Michael Littman's Avatar
Michael Littman
Michael Littman is offline
I was given a 1997 dated Ford radio/CD. I want to install it into my 1994 F150. Will this unit just drop in?
Old 01-07-2004, 11:28 AM
Frdbuy8589's Avatar
Frdbuy8589
Frdbuy8589 is offline
Arn't the 97 and up radios din and a half? In other words is the face or front of the radio lager or taller then the one in your 94? Theres 3 sizes of headunits DIN, DIN AND A HALF, or DOUBLE DIN.
I know the one in your 94 is a DIN. But what do you mean dated? If it was made in 1997 for something then maybe but if its from a 97 f150 then no.
Old 01-07-2004, 03:36 PM
Talyn's Avatar
Talyn
Talyn is offline
Get the dremmel and some epoxy and plastic out.
That baby WILL fit.
Old 01-07-2004, 04:05 PM
optikal illushun's Avatar
optikal illushun
optikal illushun is offline
it wont fit because it is DIN and half in size and u can cut any of the dash out.
Old 01-07-2004, 11:33 PM
Talyn's Avatar
Talyn
Talyn is offline
Help if i knew what a din was. =(
Old 01-07-2004, 11:35 PM
optikal illushun
all modern car makers use a basic classification for radio sizes. the standard is a DIN which is what ur truck has. a DIN 1/2 is slightly bigger and comes in most new fords (aka that 97 HU) and finally there is a double din which most GM and mopars use. its basically 2 DIN stacked on top of each other size wise.
Old 01-08-2004, 03:28 PM
drunkenmonk's Avatar
drunkenmonk
drunkenmonk is offline
most GM and Mopars use DIN and 1/2, double DIN is mostly an import thing, although some newer domestics use it.
DIN is@ 7"X 2"
DIN and 1/2 is @ 7"X 3"
double DIN is @7"X 4"
Old 01-08-2004, 03:39 PM
optikal illushun
whats an import :-p
Old 01-08-2004, 05:30 PM
Talyn's Avatar
Talyn
Talyn is offline
Okay. Thats what i figured it was.
Thanks for the clarification guys.
Yep.
dremmel and epoxy and some plastic. =D that baby WILL fit. :P
Old 02-13-2004, 01:45 PM
prcrboy's Avatar
prcrboy
prcrboy is offline
I did build an enclosure for floor board and install a new style dual media radio from an explorer and it works great. There are harnesses you can buy without having to cut and splice anything.
As far as the old radio, just find a blank plate from a xl model in a junk yard or for fun, find a "tray" out of the 94-98 modle tbird and install in opening.,
plowhand
1997 - 2003 F150
06-16-2012 08:31 PM
intruder1239
02-13-2012 08:50 AM
Packard V8
1999 to 2016 Super Duty
01-28-2012 09:34 PM
cstrack
12-10-2007 04:24 PM
Tell3131
05-22-2004 07:20 AM
Quick Reply: Will A Ford '97 Radio/CD Fit Into My '94 F150?
