4.0 ohv firing order?
Just bought a '92 Ranger with 4.0 ohv, auto, 2wd, 110k mis. Doing a little tune up, new filters, plugs, wires. I put in standard motorcraft plugs, awsf-42c, gapped at .054, and 8mm Bosch wires. Started it afterward and it runs like crap. I think it's missing on a few cylinders and the exhaust smells like unburned gas. I wondered if I had rewired the plugs in the wrong order. Can someone verify? I read on another board that the Chilton manual has it wrong. Thanks for helping a newbie to Rangers and Ford-Truck Enthusiasts!
The way it was wired before I started...
Engine
654 \ cylinders (front of car-> )
321 /
465 \
321 /
ignition coil pack in order of plug wires(front of car->)
Engine
321 /
465 \
321 /
Sorry about that, my memory must be slipping, just checked mine and your right. I would pull one wire at a time until you find the cylinder thats not firing and then swap the wire to another cylinder and see if the miss fire follows the wire. You will need to use something insulated. If it follows then bad wire, if it stays do the same with swapping plugs. Did you use dielectric grease?
Crackerjack -
I would seriously consider purchasing a Haynes manual. Less than $20 and includes all specifications for your ranger. I purchased one about 7 years ago and use it every time I do maintenance or repairs, it has never let me down. You can get one, specific to you truck, at Autozone. Hope that helps!
Originally posted by rangerx93
Crackerjack -
Crackerjack -
P.S. Welcome to Ford Truck Enthusiasts!
mdelfunt
06-26-2017 11:12 AM
