1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Front Brake Rotor Replacement
Old 12-13-2003, 10:37 PM
azguy2's Avatar
azguy2
azguy2 is offline
I have a 1999 Super Duty 4 x 4. I want to replace the front rotors myself. I have done numerous cars and a Jeep TJ but never a 4 x 4 Superduty. Usually I loosen two bolts on the caliper, lift the caliper of the rotor, and tap the rotor off the spindle. What is the procedure for a Superduty 4 x 4? Do I mess with the hub? When I compress the disks do I need to be concerned about the AntiLock brakes.? Help
Old 12-13-2003, 11:06 PM
valvestud's Avatar
valvestud
valvestud is offline
Your intended procedure is how I do my Excursion, which should be the same as the SD. No need to deal with the hubs since the rotors slip over em. Use a plate or block of wood and a large C-Clamp to compress the caliper pistons.
I would also be careful about what rotors you use as replacements. The factory units are notorious for warping. I replaced mine with the ART units, and they seem better than Ford's.
Next time, I'm going to use Performance Friction two piece units. ART uses Performance Friction pads when a customer orders them, and they're the onl;y pads I use.
Regards,
Joe
Old 12-14-2003, 02:05 AM
Monsta's Avatar
Monsta
Monsta is offline
Sit. Stay.
You can also just use the old pad and a C-clamp. It may be easier to find...
Old 12-14-2003, 06:13 AM
jschira's Avatar
jschira
jschira is offline
The caliper bolts use Loc-Tite, so they are a PITA to break loose.
Old 12-14-2003, 05:40 PM
Fordman4x4's Avatar
Fordman4x4
Fordman4x4 is offline
If the front rotors have never been off, they might give ya trouble...Spray some WD-40 around the hub. Spray behind the rotor too, let it sit for a while. Then get the baby sledge ready just in case.
Nelson
Old 12-14-2003, 07:23 PM
azguy2's Avatar
azguy2
azguy2 is offline
Thank you everbody for all the good information.
Old 12-15-2003, 12:10 AM
Monsta's Avatar
Monsta
Monsta is offline
Sit. Stay.
Nelson
Speaking that...you can replace the word "rotor" with "wheel". Sometimes they can be a pain to get off, too!
Use some anti-sieze on the mating surface of the rotor and rim when reinstalling to prevent it in the future.
Old 12-15-2003, 03:39 PM
Fordman4x4's Avatar
Fordman4x4
Good call Monsta...
I remember the first time i took my stock tires/wheel off, what a pain. It took some heavy swinging with a large rubber hammer to get them off. I made sure to put some anti-seize on the hub.
Nelson
hydrosmith
11-29-2010 09:28 AM
dgpach
01-29-2010 04:51 AM
electrified_cc
05-31-2007 01:49 PM
goldsworthy
1997 - 2003 F150
09-09-2006 09:13 AM
biederboat
02-12-2003 08:13 PM
Quick Reply: Front Brake Rotor Replacement
