Pops truck needs carb
85 351w is it a 4bbl or 2bbl? if it is a 2bbl i would just buy a holley reman carb from the auto parts store. if it is the 4bbl factory carb, then it is the 4180. i would replace it with a holley r-80457 carb. priced less than an edelbrock, and you wont have to do any jetting like the edelbrock. it was designed as a replacement carb for the 351-460 application. plus it has the ford transmissin kickdown linkage on it, as well as an electric choke. and at a list price of 239.99 through jegs, you cant beat the price.. Kurt
Personally, I think edelbrocks are a good carb just to bolt on and go. I have a 600CFM manual choke 1405 on mine, and it runs great after I adjusted the idle. Holley are easy to adjust, but most people I know are always adjusting theirs.
f100guy, whats a edelbrock 1408? I didn't see it listed in the catalog..
the biggest problem i have seen with the edelbrock is the lack of good low vacuum enrichment. most of the people i know with the manual trans are always complaining because of the ping off idle while towing. there is no real way to adjust it out. they really lack tuning part. the other problem i have run into, is that they only seem to last a couple of years, and then you throw it out. i see them all the time with bowl corrosion. the pot metal they went to a couple years ago doesn't seem to hold up as well. they even state you shouldn't run one when there is a chance of alcohol blended fuel. if you are going to run a edelbrock carb, buy the carter. it is the same carb made at the same weber factory! atl east it comes with the ford kick down lever installed, as well as the electric choke. i hate it when people come in and state "it dosn't kick down, and it shifts funny" and you lok at the intake an the fn lever is just sitting there with the mounting hardware gone. the listing on that carb is part # is 9637. stay away from the 750 unless you plan on installing a blower with 4 pounds of boost or running your motor to 9000 rpms. the most a 460 will flow with an intake, headers and street cam is 580 cfm at 90% ve and 5500 rpms. infact for better low and mid speed operation i would really recomend a 450-500 cfm. ok you run out of carb at 4500 rpms, but come on when was the last time you ran that 460 to 4500? by the way there is no 1408.. Kurt
yeah chances are you are a bit rich on the low vacuum enrichment. on the larger motors unless you go to the larger carb you cant tune out the low vacuum enrichment system enough to eliminate the ping. if you go with the 750 you loose a whole bunch of drivability as well as gas milage. wish they had a power valve, even the ford 2100 and 4100 had a power valve to fix the problem.. Kurt
yes but you are really limited to the sizing you can change. either you run a little lean on the main circut( high end of the rod) or yoy run lean on the low vacuum side. they rods are too "generic" and tuning out with a 14.7 mixture can often be a real problem. chance are you can richen up the low vacuum, but in doing so you also risk changing the cruise mixture if the upper rod isn't the same, or you have to go to a smaller jet and start over again. Kurt
mikeinmilton
06-10-2015 03:10 PM
cleanLX
01-17-2004 12:22 AM
1406, 1408, 80457, carb, carburetor, choke, edelbrock, ford, fordtrucks, holley, jets, model, problem, transmissin, tuning
