Offroad & 4x4
off road carb
Old Jul 28, 2004 | 04:52 PM
FORDbigblock4X4's Avatar
FORDbigblock4X4
off road carb
whats a good carb for a 460 that is stock except for a new cam i looked somewhere that said this engine needs a 800 cfm or more carb any one know for sure? also should i get a holly or an edelbrock?
Old Jul 28, 2004 | 10:05 PM
gilraine's Avatar
gilraine
a mostly stock 460 should run fine with a 650 CFM carb...you'll lose a little top end, but pick up some fuel economy.. as for carb selection, I liked my 650 vaccum secondary holley..
Old Jul 28, 2004 | 10:06 PM
fishmanndotcom's Avatar
fishmanndotcom
for offroad purposes it is hard to surpass the Holley Truck Avenger. with a mild/hot cam get the 750/800 cfm flavor !
-cutts-
Old Jul 28, 2004 | 11:23 PM
proeliator's Avatar
proeliator
Holley truck avenger 770. Used it myself on one of my trucks, worked great.
Old Jul 29, 2004 | 08:56 AM
KJKozak2's Avatar
KJKozak2
My 78 F150 460 4x4 has a Holley 750. I haven't had any problems with it and we do a lot of wheelin'.
For the ultimate off-road carb that will run at any angle, convert to LP. It's an amazing setup!
Kevin K.
Old Jul 29, 2004 | 11:07 AM
176ford's Avatar
176ford
what is an LP?
Old Jul 29, 2004 | 11:12 AM
KJKozak2's Avatar
KJKozak2
Liquified Propane. Same stuff you use on your gas grille.
Cheaper than gas and not too expensive to do the conversion.
K.
Old Jul 29, 2004 | 11:16 AM
fishmanndotcom
and if you run it on a diesel it is like putting nitrous on a honda civic! gives iy mucho power and it does burn cleaner.
-cutts-
Old Jul 30, 2004 | 01:17 AM
hoxiii's Avatar
hoxiii
If you don't wanna shell out the cash for a new carb, get a quadrajet 750 off of a GM. They're the closest you can get to "unstallable" w/o going FI. You can also pick them up for $50 all day long.
Justin
Old Jul 30, 2004 | 10:40 AM
Momudder720's Avatar
Momudder720
Where can I find what I need to do an LP conversion?
Old Jul 30, 2004 | 10:55 AM
KJKozak2's Avatar
KJKozak2
I'll ask my cousin this weekend where he got all his stuff from and let you know Monday.
Til then READ THIS for some good info, and do a google search for "LP conversion". There's tons of good info available.
Good luck.
Kevin K.
Old Jul 30, 2004 | 01:01 PM
fishmanndotcom
here's some other links to look at
http://www.pirate4x4.com/tech/propane/index.html
http://www.pirate4x4.com/forum/showt...hlight=propane
these are just to get you thinkin some....nothing real specific. you go to the diesel stop or pirate they have plenty of stuff on LP
-cutts-
Josh McReynolds
Dec 1, 2016 05:14 PM
Viperfoxbat
Jul 8, 2016 04:55 PM
68Ford4Life
20
Jan 18, 2012 04:26 PM
460way
15
May 13, 2006 02:22 AM
uncle jessie
Feb 23, 2005 11:20 PM
