Diiference between a single wheel and dually axle
Can someone tell me what, if any, the difference is between the rear axles on a 91 f-350 single rear wheel and an 89 f-350 dual rear wheel. Does the dually have the same axle and just the extra wheels? Or is the axle actually bigger? My 91 SRW has a GVWR of 9200 and my buddy's 89 dually is 10,000. Is the braking system different? Thanks for the help!
All dually's from 80 up used the Dana 70 rear. They didn't start using the dana 80 rear til the SD. If any pre SD had the D80 it had to been swapped in or was a heavy utility truck.
your 91 will have the sterling 10.25 rearend and his 89 dually should have the D70.
Since your wanting to make the swap head to the wrecking yard and find a daully donner truck to rob the rearend and springs from. Besure It comes from daully that came from the factory with a bed and not a Cab & chassie they use narrower frames then a bedded truck. Since your truck is a F350 your braking system is the same used on the daullys. It'll all bolt right up.
BruteFord
74
08-21-2016 09:55 PM
