magnaflow w/o cats?
Old 11-21-2003, 08:44 PM
packlet's Avatar
packlet
packlet is offline
magnaflow w/o cats?
hi guys!
My 82 E350 van w/ mildly built 400 currently has dynomax headers (1-1/2" primaries, 2-1/2" collectors) into a 2-1/2" to 3" Y-pipe to a single Flowmaster 50 Deltaflow and 3" tailpipe. No cats.
This is simply too loud, especially inside the open space of the cargo van. The resonance at idle and around 45-55mph is quite something...
I purchased a larger Mganaflow (12589, 5x11x22" oval with single center in/offset out - about ) and showed it to my exhaust guy, who claims to have 23yrs experience with racing exhaust systems.
He told me the straight-thru design of the magnaflow is intended for system with catalytic converters, which act as a sort of pre-muffler, and that this muffler on my system will be LOUDER, even tho it has about twice the internal volume of the Flow 50.
I wish i could just try the magnaflow, but then i wouldn't be able to return it if my exhaust guy is correct...
what do you think? Do I NEED a baffled muffler for maximum quiet? Has anyone out there compared a flow 50 to a bigger magnaflow on a system without cats? If the magnaflow is not the right thing, what is for maximum quiet without too much restriction? Flow 70 maybe? or big Gibson? or maybe i should add a resonator in the system before the muffler?
Thanx!
Old 11-22-2003, 01:09 AM
95 F150's Avatar
95 F150
95 F150 is offline
I'm no exhaust expert here but on my truck my system is shorty headers, single 3" pipe after y pipe with 2nd cat removed to a Magnaflow SI/DO oval muffler and it's about upper low to medium loud. I ran a 30" glaspack as a resonator for a while and it didn't quit it down much at all if any.
If your really wanting to tone it down you might consider a Gibson or Borla muffler or maybe a 3" highflow cat. That will make it more quit and the state of California will like you that much more .
Keep on truckin' ...Mike
Old 11-22-2003, 02:47 AM
packlet's Avatar
packlet
packlet is offline
thanks, mike.
i run no cats cuz this beast never had any cats nor need them to be CA legal.
i might consider adding a cat, if it makes it more quiet and/or easier to pass smog, but i'm pretty sure it would pass as is. i have kept EGR, AIR, etc, and it's running quite lean.
just noisy...
Old 11-22-2003, 11:07 AM
95 F150's Avatar
95 F150
95 F150 is offline
Makes no diff. to me if you have cats or not, I'm runing catless myself. I just know that catylytic convertors have quite a muffling effect on the exhaust tone and adding a high flow unit by catco or the like might be a cheaper alternative then messing around with expensive mufflers .
Old 11-22-2003, 12:02 PM
packlet's Avatar
packlet
packlet is offline
good point. thanx.
Old 11-22-2003, 02:03 PM
MikeRF90744's Avatar
MikeRF90744
MikeRF90744 is offline
I just put a Magnaflow on my 97 4.0 Ranger.. and it sounds about like stock, its real quiet, I was disapointed when I got it on because I wanted more sound than this muffler had to offer, the guys at the muffler shop told me before I had them put it on that people are complaining about how quiet they are,
Old 11-23-2003, 01:39 AM
_GEEZER_'s Avatar
_GEEZER_
_GEEZER_ is offline
Currently running a Mflow on my '89 Big body / 5.0L. After the Y-pipe, it's a 3" single exh. all the way back, with a hollow (3" pipe straight through) catalytic converter. It has a very mellow tone actually, and is quite pleasing under acceleration. Barely more audible than normal at idle, and w/ slight resonation only around ~50 MPH.
It's actually not really as aggressive sounding as (I'd like) but sounds to be like just what you may be looking for. Good luck.
Old 11-23-2003, 02:18 AM
packlet's Avatar
packlet
packlet is offline
geezer,
does the 3" pipe thru your fake cat have holes in it? or is it solid? i understand a hollowed out cat would act as a resonating chamber and would be quieter than a 3" pipe without a resonating chamber, like i currently have. If you do indeed have a solid 3" pipe running thru your cat and find the Magnaflow to be quiet, that may the 'vote of confidence' i need to at least try out the one i have...
thanx!
Old 11-23-2003, 07:47 AM
openclasspro's Avatar
openclasspro
openclasspro is offline
walker dynomax mufflers- ultra flows are very quiet!
Old 11-23-2003, 01:44 PM
_GEEZER_'s Avatar
_GEEZER_
_GEEZER_ is offline
No, there are no holes in the thru-pipe. (Somebody correct me if I"m wrong, here) but I'm under the impression that holes in the pipe or just a hollow cat as so many people run; will actually cost you a small amount of power, as the rapid expansion (cooling) and then compression (heating) of the exhaust gases when flowing from the 3" pipe, into a ~8" pipe (false cat,) then back to a 3", is unnecessary and inefficient.
Old 12-03-2003, 05:50 PM
packlet's Avatar
packlet
packlet is offline
i did it
I had my exhaust guy swap in the large Magnaflow for the FlowMaster 50 Deltaflow. He was surprised that the straight-thru magnaflow was NOT louder than the baffled FM. I was pleased to find it quieter, especially at idle and ~65-70mph. There is still some resonance around 45-55mph and under load, but it's definitely more tolerable overall. I think i can live with it now...
cheers!
RR24
Modular V10 (6.8l)
13
06-17-2014 10:27 PM
Wisconsinford
04-09-2013 07:59 PM
hivoltj
16
11-18-2010 07:58 PM
scooterscott
1999 to 2016 Super Duty
11-09-2006 06:56 AM
ceetwarrior
28
07-26-2005 08:47 AM
Quick Reply: magnaflow w/o cats?
