window replacement for '99 ranger
A while ago I had someone break into my truck through the driver side window; back then I was on very limited finances and had the window replaced for as cheap as I could find, and it shows.
when they replaced the window, the fit was so tight that eventually the handle broke from the force I was exerting to roll the window down and up.
what is it that they screwed up when they installed my window so I can fix it myself and save a buck or two.
regulator
I have 98 with power windows and I replaced regulator because of a charder (sp?) issue. I got a new regulator from the Ford dealer for only $14.00. I would replace regulator with a new one to be safe. They are pop rivited in with very large alum. rivits. You will have drill out the old ones. You will need a cordless drill if you have remove the window in a junkyard. You can get the rivits from NAPA. I also beleive that the window was not installled correctly in the first place.
Rick
Rick
teerex
1997-2006 Expedition & Navigator
11-11-2013 08:30 PM
boo-yaa138
08-30-2013 01:11 PM
