Bronco II Ford Bronco II
Gas Tank Size
Old 10-28-2003, 05:03 PM
Mike Cook's Avatar
Mike Cook
Mike Cook is offline
Question Gas Tank Size
I have a 88 Bronco II and I would like to know does anyone have
any idea how many gallons the gas tank holds
Old 10-28-2003, 06:34 PM
knucklehead11's Avatar
knucklehead11
knucklehead11 is offline
I believe about 23 or 24 gallons.
Old 10-28-2003, 08:47 PM
_rich_'s Avatar
_rich_
_rich_ is offline
Old 10-29-2003, 10:15 AM
jclopezv's Avatar
jclopezv
jclopezv is offline
MMHHHH.... I have a 1987 xlt, I put gas on it when the gas gauge goes almost down (I do not get a warning light), the avg gallons I put in it are 10, Is it possible that my gas gauge is bad or is it possible that I have a smaller tank? Mike, are you having the same thing?
Old 10-29-2003, 05:13 PM
pat67shorty's Avatar
pat67shorty
pat67shorty is offline
Gauge is bunk. My guage has been off ever since I've owned mine.
Old 10-29-2003, 07:59 PM
Mike Cook's Avatar
Mike Cook
Cool
When my Gauge is almost On "E" the tank apears to only hold 13
gallons or at least that is were the pump stops and if you try and
put in more it will not take it, so yes it is almost like yours
Old 10-29-2003, 10:40 PM
knucklehead11
I think everyone's does that at 10-13 gallons. Mine's just a screwy gauge (I think I have a bad sending unit). It'll go all the way to E on fillup (low fuel light comes on). After 10-20 miles of use, the gauge goes up to F and the light goes off. After a while it'll go down to 3 quarters full or half, just differs all the time, and it never shows an in between reading, and then eventually a quarter full, and then by the time I hit about 200 miles (which is about 12 or 13 gallons used on my truck, and I run my RPMs kinda high when I drive, and cruise around 3k RPMs on the freeway) the gauge reads E and the light comes on.
Old 05-09-2004, 06:01 PM
lou cav's Avatar
lou cav
lou cav is offline
Smile
I had to change it on my 86 bronco II, it's 23 gallons.
Old 05-09-2004, 08:33 PM
Aggie05's Avatar
Aggie05
Aggie05 is offline
im not sure on gallons i usually put it about 19 to 20 on my 89 bronco II 4x4.
but my father owned a like 91 i think Dodge Ramcharger, it had like a 30 gallon somthing tank on it but everytime we went to put gas in it it only held like 15 or so... Finallly found out that the pump in the tank had come lose and was sitting in there at an angle, so even though there was plenty of gas in tank, fuel pump couldnt suck it up.
just a thought
Old 05-10-2004, 01:04 AM
CherryColaholic's Avatar
CherryColaholic
CherryColaholic is offline
mines 23.. checked specs in manual.. you either have a 15 or 23. 15 was standard.. most people obviously sprung for the 23. anyway.. now you know.
Old 05-10-2004, 05:00 AM
nogo73's Avatar
nogo73
nogo73 is offline
I'd always figure out my mileage everytime I went to the gas station and I'd get pretty close to puting 21 to 22 gallons in all the time I always got around 350 miles before I'd fill her up.
Old 05-12-2004, 12:58 PM
stuwiley's Avatar
stuwiley
stuwiley is offline
I just put a fuel pump in My 88 BII.When I dropped the tank,it still had 11-12 Galllons in it.The gauge read empty.i know its a 23 Gal. tank.But it never takes that much...
SouthernBlues
02-02-2017 05:39 PM
Michael Poss
01-01-2017 03:02 PM
volwing1
6.2L V8
08-14-2015 06:54 AM
Milwaukee1979F150
15
01-26-2010 06:03 PM
freeky1
09-13-2002 11:40 AM
Quick Reply: Gas Tank Size
