6.9L Going Into Storage
Old 09-30-2007, 10:43 PM
Cool6.9DieselGuy's Avatar
Cool6.9DieselGuy
Cool6.9DieselGuy is offline
I"m about to rip out a 6.9L and put it on a pallet to set in the back of the garage or the shed or something... I'm just trying to get some opinions on what I could do to keep the internals in good shape... particularly the coolant passages, as this diesel to my knowledge has never been treated with sca/dca additive... Should I run some coolant flush through and then maybe put the right antifreeze in and run it for a little while to coat the insides before I drain it, or should I just say F it and drain it and put it right on a pallet? Any other ideas? thanks guys
Old 09-30-2007, 10:54 PM
catfish101's Avatar
catfish101
catfish101 is offline
Spray the cylinders with something that will oil the cylinders good and let it be. I have used outboard boat motor cyl "fog".
Old 09-30-2007, 11:24 PM
David85's Avatar
David85
David85 is offline
...and turn over the engine by hand a few times after fogging it.
Old 10-01-2007, 06:28 PM
F250FarmBoy's Avatar
F250FarmBoy
F250FarmBoy is offline
Make sure you strap it on good, dont want that big hoss falling over and damaging it, something else, or someone's toes...
Old 10-01-2007, 11:06 PM
Cool6.9DieselGuy
nobody thinks I should do anything to the coolant system? would it just be a waste of money?
Old 10-02-2007, 12:57 AM
David85's Avatar
David85
David85 is offline
SCAs provide extra protection when the engine is running, but for storage, I would just drain it and wrap it up real good.
Old 10-02-2007, 08:45 PM
chrono4's Avatar
chrono4
chrono4 is offline
How long is it going to be stored?
Old 10-05-2007, 08:06 PM
Cool6.9DieselGuy
maybe like 10-20 years
I'm not sure if David85 has me convinced, I think I'd rather know for sure that when it comes time to use this motor again the coolant passages aren't all rotted out inside
Old 10-05-2007, 08:10 PM
bigredtruckmi's Avatar
bigredtruckmi
bigredtruckmi is offline
For tha long term. I would seal all areas where air/moisture could get into engine. Best thing would be a shrink wrap for the whole engine.
Old 10-11-2007, 06:46 PM
Cool6.9DieselGuy
great thinking!
Old 10-18-2007, 07:29 AM
chrono4's Avatar
chrono4
chrono4 is offline
a good heavy weight oil on all the surfaces and cover with a breathable cover. Dont shrinkwrap it. If you do, when the block sweats from the air warming up, it will condensate under the wrap and then there will be nothing but a haven for rust.
Old 10-19-2007, 12:30 AM
Cool6.9DieselGuy
EVEN GREATER THINKING!!! I'm glad you read this thread
whalebus2112
Ford Truck Parts for Sale
01-22-2014 04:23 PM
mozzles
26
10-11-2012 05:36 PM
Aune163rd
17
02-23-2011 03:21 PM
turbill
10-26-2010 09:25 PM
cigarxtc
Garage & Workshop
01-04-2003 10:07 AM
Quick Reply: 6.9L Going Into Storage
