6.9 engine crate/pallet
Old Oct 26, 2010 | 11:09 AM
turbill's Avatar
turbill
Does anyone have dimensions for a pallet to hold a 6.9. you know where all the motor mounts will be. I might be buying an engine and need something to bring it home on. I have access to boat motor pallets so i figure i'll mod one of those, or just build from scratch.
Old Oct 26, 2010 | 11:10 AM
turbill's Avatar
turbill
also what size bolts will i need to bolt the motor to the pallet
Thanks in advance
Old Oct 26, 2010 | 03:37 PM
tecgod13's Avatar
tecgod13
Where in western mass are you?
I have a 7.3 sorta mounted on a pallet if you wanted to take some measurements yourself.
The bolt size might depend on where on the engine you place the bolts. What I did was use a couple 4x4's with a piece of metal bolted to the top, the metal then bends to where it can bolt onto the motor mount. Then a couple 2x4's propped under the back, and a ratchet strap on each side.
Old Oct 26, 2010 | 07:21 PM
johnboggs21's Avatar
johnboggs21
jus set the motor in a big tire and strap her down good
Old Oct 26, 2010 | 07:51 PM
turbill's Avatar
turbill
Ha ha, well i don't have any big tires, and i might be doing a few things to make the engine better/sexy, so i want more access that i think a tire might not provide.
But hows this sound for a deal, 350 bucks for an 87 with 77,000 orig miles, might not be as good as they guy is saying it is but but It's definitely worth a look i think
Old Oct 26, 2010 | 08:09 PM
johnboggs21
could almost get 350 in scrap
Old Oct 26, 2010 | 08:13 PM
turbill's Avatar
turbill
yeah I figure I'll just about break even or maybe better after i part out/scrap my current engine
Old Oct 26, 2010 | 08:15 PM
johnboggs21
yup, so thats literally a deal ya cant pass up, especially if theirs the potential to make money off it
Old Oct 26, 2010 | 08:22 PM
turbill's Avatar
turbill
Yeah should be!
Old Oct 26, 2010 | 09:25 PM
charleswood6969's Avatar
charleswood6969
As part of an answer, the rear of the block uses 1/2 inch coarse threads. If ya need any exact dimensions, I can measure the one I have on the stand pretty easy and let you know.
JUSTICE1736
Feb 27, 2016 10:30 PM
52 Merc
Feb 22, 2016 12:43 AM
brocluno
1978 - 1996 Big Bronco
Sep 29, 2015 12:03 AM
charleswood6969
Jul 26, 2015 09:47 PM
Ranger1F150
Sep 22, 2007 10:47 AM
