FW-15 additive for the cooling system...
Is everyone using this Ford additive FW-15 in your cooling systems? I just replace the fluid in my 01' Excursion over the weekend.
Drained it, flushed it out and added 4 gal of Zerex GO-5 gold coolant along 4 gal of distill water and 1 bottle of FW-15. The FW-15 cost me $21 bucks from the dealer. The owners manual is calling for 4 pints of it (4 bottles).
Is this additive really needed? Don't the coolants already have additives to fight build up in the cooling system? If FW-15 is really needed, I'll go get enough to put in my truck. Just want to make sure before dropping another $65.
By the way, the dealer here wants $220 bucks to flush out the cooling system for a PSD.
Thanks,
Thanks,
If you dont use the additive, cavitation of the block and cylinders will result and cylinder failure could result. I have seen cylinders break in half from low DCA levels in the coolant. FW-15 and coolant flushes are CHEAP insurance against this happening!! Use it per the owners manual guidelines. I add two pints to mine every 15000 miles, drain and refill every 30000.
Originally posted by Savaged1
Great! I used the GO-5 Gold coolant, so I won't have to get more FW-15 then.
Thanks alot guys!
Thanks alot guys!
If you used gold coolant in your cooling system that originally came with green coolant this could be a major problem for you. Even if you completely flush the system Ford will still tell you the two are not compatable. Basically, if your truck came with gold, use gold. If it came with green, use green.
And FW-15 is now FW-16. Your Ford dealer is ripping you off with the price. I suggest buying online from someplace like Diesel Injection Service.
Originally posted by johnsdiesel
THE GOLD AND GREEN COOLANTS ARE NOT COMPATABLE!!!!!!
Freaky phenomena, cavition. The cylinder walls actually vibrate in such a way that keeps the coolant from touching the walls. Is this correct? I know it's needed, so I bought a bottle from the dealer ($8.95) and put it in the overflow tank. Will this work? Or do I have to add it to the system some other way? I don't have an owners manual for my truck...how often should one add a bottle of additive?
TCASMER
02-01-2008 12:27 PM
