on my 89 ford f-150, the power window motor will run, but won't move the window. i can push the window down with my hands also. if the window is up, and yes it will stay up, and i hit the up button, the motor will run, but the window will slide down into the door. the window will go up, but only if i help it. any ideas? thanks in advance.
This window motor has three small cylindrical rubber type blocks inside the gear unit, they take up the cushioning of the motor going up and down, the rubber blocks break up in time, then the window motor does not do its job.
