Hi. I thought I would share a few pics of my 1985 F-800 bucket truck with a Fabco 4x4 drive train. 7.3 diesel. Air brakes and air select for 4x4 and range and an Allison auto trans. And those tires!
7.3 and not a 6.9 in '85? Swapped out st some point? Still pretty cool. Was a tree trimming company truck.
Guess it's not a 7.3L, but a 7.8L according to the tag on the valve cover.
Either way that means it's a newer engine? It says 1990, so I guess it's at least that new. Good news as far as I'm concerned. It's not like it's a collectable truck.
I was told by the place I bought the truck from that it came from an electric company. They bought 2 of them but the other one had normal tires and duals on the back.
the 7.8 is actually a good running engine.
pulls 25 ton total truck/trailer/load weight in the single axle with a 5 speed and 2 speed rear with no problems at all.
It seems to run pretty well to me. Plus I believe it I was so inclined I could turn it up a bit. You could order engines with different HP ratings. The truck goes 70 on the highway no problem, although highway miles with it are probably over and I only did it that one time because I didn't know any other way to get it home from where it was. Too tall to put on my trailer at over 12 feet as it sits. I keep to secondary roads now.
