K&N Air Filter - 2002 V10
i learned the hard way with K&N filters if you get one here are some tips
1. after you open the plastic wrap around the filter let it air dry for several hours before you put it in
2. when you clean it give yourself atleast one full day for the water to dry and for the oil to soak in before you replace it.
3. buy the pre wrap that goes on the outside of the filter
4. clean your MAF regularly so that it doesnt get ruined from excess oil and dirt
personally i would look at AFE or some other brand and get a dry flow filter one that does not need to be oiled. its one thing to buy a cotton filter and it is another when you have to buy the cleaning kit to take care of it. me personally i get the motorcraft filters. they are way cheaper and ford designed them the way they are for a reason.
No not a factor filter. I have had a K&N intake on mine for almost 10 years now. No dusting, no MAF issues, no problems. I check the tube and MAF regularly. But I know how to clean and oil the filter. I also have an outerwears on the filter which helps keep it clean. The filter clamps on mine, its not a drop in.
If the drop filter doesn't fit the intake housing just right it can let in dirty air.(which is not an isolated problem)
Makes sense that Motorcraft would be factory. I ***-u-me d, because my used 2002 F-250 V10 had the K&N when I bought it, that it came that way from the factory. My bad!
I do know that in the early days of automobiling up the the late 50's manufacturers used oil bath filters. The switch over to dry elements was not to increase filtration efficiency, but because of convenience.
I also realize that an oil bath filter is not the same thing as an oil bath filter.
I also KNOW that I have had to clean the MAF sensor on my 136K engine with the K&N.
