Zoodad mod is all you need. Stock filter is what I run, oil based filters and MAF sensors do not work well together and the K&N drop in filter I had did less filtering than it should have.
I have a S&B setup on mine. I like the sound difference but I can not state whether or not there was a performance gain since I did several things at the same time.
OP has the best Engine to come in a Excursion. The Mighty V10.
Stick with the stock filter, save the money in my opinion. I used to have the Volant on my 5.4 Expedition back in the day, not much to be had except for some noise.
Indepentendant lab testing has repeatedly proven that the Donaldson powercore media is superior at filtering dirt. If you are looking for an air filter that filters out the most dirt then there is a lot to be gained by putting on a better filter.
