Fuel Pump?
Fuel Pump?
Alright so last night my bump did not really want to start and after a few pumps she fired but ran really slow and clumpy, I had just drover her hard earlier so I thought maybe she was tired. This morning I could not get her to fire. starting fluid made no difference but a sputter.
after jumping my truck and some more starting fluid she kept starting and dying. After plenty of choice words at 6am, she started but with my foot on the floor she just idled extremely low. so I got her going and warm, seamed to be running and responding right, but my guess is dead pump (pumps quite a few years old), lines are newer and tank is clean.
Do pumps work and not work as they are dying? i know i can pull the line off the carb and check, but the intermittent part of my problem seams to be that 'something' is dying.
I have been driving her without issues for the past two weeks, this just started. she purrs normally and fires right up with a single pump.
any advise? should i add a 30 buck electric pump to help prim it up, or just replace the mechanical, or even both?
Not usually but it is possible. There are one way valves in there that normally let inbound gas stay inbound and the opposite for the outbound port. Maybe one of these is on it's way out.
Take the fuel line off of the carb, put a hose on the metal tubing and get a 1 gal container. Have a friend crank the engine over as you point the hose into the container. It should have a strong surge of gas coming out. If it's just going out in sperts or drooling, check/replace the filter. Try again, same problem, get a new pump. Quality electric or stay with stock pump. You don't need or want both.
Rubber lines between the tank and fuel pump can crack and suck air, even intermittently. I never replace a "bad" fuel pump unitil I check with a vacuum pump and a catch jar to make sure a good flow is available TO the pump. Also I've seen issues with the cam that drives the pump, though not often.
So it's sucking at the canister. Pump and lines checked clear and good. Found it leaking today. Bought new filter and gasket but I can't get it to seal, like the gasket is to large. In the can it fits but flares on the pump. Unless I can get another gasket or shrink this one... I think I'm stuck again. Wasted and wearing gasoline with ice cold beer scratching my head. I had a hard time last time I changed the filter, but it sealed. Found crappy in the can too so I was sucking air and clogged.
r_carhill
18
08-19-2013 03:54 PM
berry1234
02-05-2011 04:16 PM
