Starting Fluid to Start?
Guess what! I have another problem you guys can help me with.
So after replacing some wiring and what not, I still have an issue.
An '88 F-350 with a fuel injected 460.
So i've been having this not-start problem lately. It cranks over and fires and sounds like it is ALMOST there, but it never fired up. Yesterday I took a squirt of starting fluid and the truck fired up and ran. After a few minutes of running it shut off-- no sputtering, it just turned off. Another squirt of starting fluid fired it back up.. then it ran.. and did the same thing again.
Any suggestions of where to look? What to start with? Any sensor specificly I should mess with? Anything I can do to test it if so?
Thanks in advance!
Thanks in advance!
The rail pump is kind of a "booster" pump isnt' it? Is it possible that as soon as the fluid gets it going that the rail pump is just running it for a little while? Or what? Also, I have two fuel tanks. Wouldn't I have a pump in each plus the rail pump?
Edit:
Okay so I just have the one on the rail and one in the tank right? But with front and rear tanks, which one pumps?
Edit:
I am borrowing a fuel pressure gauge from a friend today so hopefully i'll get this issue figured out!
Thanks for the information guys. I will keep you updated and post up later tonight. (Assuming I got the gauge.)
is starting fluid bad for a vehicle?
my experiences with this chemical are limited, in the marines we used it to fire up the humvees 94-98. however the other day a buddy of mine said he would never use it on a vehicle (except a tractor) of his and said it was somewhat dangerous.
as mentioned before, we used it in the corps and we just squirted a bit into the fording stacks and they would start on a real cold day. i suppose that because i was paying taxes that they were my humvees just as much as any other taxpayers.
so, just how damaging is using starting fluid?
yeah, i guess in diesels (humvee, tractor) it's not a big deal. i think my buddy was more worried about safety than engine longevity anyhow.
oh, i'm not into snickers (dislike peanuts) but i do like pepsi or coke, whatever.
the screen name "snickersandapepsi" comes from a joke very similar to his one Political Joke Archives - A Catholic Goes to Confession
being raised Catholic i found the joke being rather funny, it became my screen name years ago. fwiw
