1994 e4od transmission lines
Old 03-02-2017, 06:51 AM
1994turbo's Avatar
1994turbo
1994turbo is offline
I have a 1994 f250 7.3 idi turbo with the e4od, and what I believe is the stock trans cooler. I have steel lines that at around the fan area switch to a rubber hose and go to the cooler. It is held down with hose clamps. I have no clue if they're stock. But the problem is now they're leaking from everywhere. I just want to cur my losses and get new lines. Any clue where I could find lines that are right? Any help is appreciated. I know they're obsolete from ford and I'm having trouble finding them anywhere else
Old 03-03-2017, 11:43 PM
speedwrench72's Avatar
speedwrench72
speedwrench72 is offline
the lines for the cooler are low pressure, fuel line will work just fine, if lines show pressure bulges then there could be a blockage, remove any after market plastic inline filters (looks like oversize inline fuel filter) these will plug with friction material rather quickly, and burst, ask me how I know, under normal circumstances pressure is below 15 lbs., temperatures can get to 240 ish
Old 03-16-2017, 10:44 PM
1994turbo's Avatar
1994turbo
Thanks for the info. Sadly the truck got totaled (I got hit, snapped the frame twice) so I will be looking for another Ford diesel. I appreciate the info you have given me.
asa67_stang
03-25-2014 12:36 PM
Pomeroy
02-17-2011 07:42 AM
WEST AUSSIE 94 250
23
09-14-2010 01:04 PM
98expeditionXLT
1997-2006 Expedition & Navigator
10-31-2008 06:22 AM
chewyjackson
03-14-2008 03:10 PM
Quick Reply: 1994 e4od transmission lines
