Replace T case, now My trans shifts weird
Put my new/used T case in. Everything went together the same as the old, now for some reason it shifts randomly at low speeds. Its even worse in four wheel drive. And when I put it in 4 high the light reads "low range". So, something seems backwards
any thoughts? Thanks
Justin.
Justin.
Last edited by Jarkill; 03-09-2017 at 11:37 AM. Reason: Title did not describe the problem accurately
Nothing a ZF5 swap won't fix haha
Sounds like the switch that tells the PCM when you're in low range is either sticking or shorting. I'm not sure how they work on these trucks. My other truck has a little ball switch on top of it that rides along the internal shift mechanism. Did you miss a plug or possibly scrape a wire while you were under there?
Well I have to be honest, all my experience with this is on Chevrolet trucks so its possible there's differences.
That being said, the first thing I'd check is the speedo gear, the gear that was in your truck is the right one for your truck, the one from the new case could be different and that could potentially cause problems. The gears are usually set for the rear axle ratio and tire sizes so unless the other truck was set up the same as yours that might be giving you trouble. If you're running 3.55s but the donor had 4.11s you're sending the wrong signal using the donor speedo gear.
As far as I know, the truck doesn't care if it's in 2wd or 4x4, just if it's in high or low range. Again, its a gear ratio thing. Most low ranges are approximately 2:1 so your shift points would be the same in 2wd or 4hi but way off in Low range.
Check the speedo gear first and go from there.
it is a manual T case. I guess I wasn't being to clear, my fault. I replaced my broken manual shift T case with an identical BW 1356. After that my e4od started shifting erratically. I solved the 4x4 indicator problem. Now I'm thinking I need to put my old Speedo gear back in. The one that came in the new one must be set up for different gear ratio.
i put my original Speedo gear back in. Its the same color as the one that came with the T case.....pink.
Update (if anyone is interested)
Pulled the old speedometer ring gear from my junk T case and installed it in my new one. Very easy procedure compared to some other things I've had to fix. Went to fire her up for a shake down and no go! Batteries decided to quit. put the charger on them and they will not hold. Picking up a set today and try it again tomorrow.
