Aerostar Ford Aerostar
Valve stem seals
Old 02-18-2017, 01:13 PM
jetfiremuck's Avatar
jetfiremuck
jetfiremuck is offline
Valve stem seals
97 4.0 starting to puff some blue smoke after just moving off. I've replaced the pass head over time but still on the original drivers head. Has anyone changed the stem seals using compressed air with engine in the van drivers side only
Old 02-24-2017, 11:43 AM
93nighthawk's Avatar
93nighthawk
93nighthawk is offline
I have no idea how you would be able to put new valve stem seals in without removing the heads., especially sense you have NO overhead room to work on those.
Old 02-24-2017, 03:48 PM
xlt4wd90's Avatar
xlt4wd90
xlt4wd90 is online now
The trick is to install an air adapter in the spark plug hole and pressurize it to keep the springs from falling in. But you're right; you'd be hard pressed to get any valve spring compressors to fit in the engine compartment.
Old 02-24-2017, 05:59 PM
96_4wdr's Avatar
96_4wdr
96_4wdr is offline
Faster and easier to pull the head. Also gives an opportunity to examine valves, valve seats and heads for any cracks and measure valve stems/valve guides for wear.
With the head off, good time to pull and examine roller lifters for wear or damage.
Old 02-25-2017, 01:06 AM
xlt4wd90's Avatar
xlt4wd90
I meant to keep the valves from falling in...
Yes, better to pull the heads for a thorough examination of all related parts.
frenchy107
03-09-2011 02:43 PM
OldSchoolRodz
07-18-2005 11:16 PM
MaximumMax001
07-19-2004 02:37 AM
nightme_02
1983 - 2012 Ranger & B-Series
07-24-2003 11:02 PM
Quick Reply: Valve stem seals
